Carbon Fiber products part 2
RobMinhas
Re: Carbon Fiber products part 2
I don't know if anyones mentioined this already but what do you think about doing CF spark plug hole covers? It would be a relatively easy product since it's basically just straight? Just a though.
- MrMazda92
I might be in for a set of spark plug covers, that actually sounds good to me. I was thinking of making a set out of Aluminum myself, but I like the idea of CF better than aluminum for that.
How about a shaped coolant overflow tank?(burp tank), that would have a lower profile and still allow functional use? Idk how well CF holds up to constant exposure to propylene glycol, but I figure it would be nice to get the ugly stock tank out of there.
- kulluminati777
yeah the spark plug covers would be legit. I would buy some (V6 of course)
- fowljesse
I would be in for anything that would save weight. I would also have it done in just FG, to save a few bucks.
jaydog is back
Spark plug covers would look cool, but I would have to figure out how to hold them down. The v-6, if I can make a cover work would only be for the front bank valve cover.
- MrMazda92
I forgot how high stock plug wires stick up... I'll need to take that into account when I modify my 8.5mm wires.
Mounting could be tough, for a one off job I would just weld 2 threaded bungs onto the VC itself, and bolt it down lightly. Others may not be so happy to weld in their engine bay though...
xxxmonoxidechild
a few different places sell the metal spark plug covers with mounts. and i know ive seen at least 1 KL with a set in carbon fiber in pics. im just trying to remember which member it was.
- Josh
Its easy to do yourself. You can buy flat pre hardened pieces of carbon fiber in most any length and width for next to nothing depending on the thickness you want and then just dremel the shape. buy a couple of studs for the center two valve cover bolts and you are good to go.
+1 customer right here!
pretty much any carbon fiber components you make ill buy
because of race car
because of race car
Ya Marco did this with the purple valve covers - looked absolutely sick.xxxmonoxidechild wrote:i know ive seen at least 1 KL with a set in carbon fiber in pics. im just trying to remember which member it was.
- MrMazda92
I think a coilpack mounting bracket would be cool, but few MX-3 owners would buy one...
How about these in carbon fiber?
Handbrake handle
Battery tie-down
Shift knob(MX-3 design of some sort?)
Rearview mirror(not a cover, but an actual 2 piece mirror, minus the glass) - If you put a piece of angled plastic around the black portion of your mirrors btw, you can direct moisture down and away from the glass, 100% avoiding the issue of it rusting around the edges.
A front license plate mount would be nice too.
Handbrake handle
Battery tie-down
1 word.... carbon fiber hatch!
- kulluminati777
easts1d3 wrote:1 word.... carbon fiber hatch!
how much have previous carbon fiber hatches going for?
- kulluminati777
800 pluseasts1d3 wrote:how much have previous carbon fiber hatches going for?
