Still to buy:
Clutch.
downpipe flange.
Oil lines.
injectors.
lambda boss.
few more silicon joiners now the turbo has changed.
lots of various hose clips.
Still to do:
fit clutch.
clock the turbo.
sort water unions on turbo
modify oil drain outlet on turbo.
make downpipe.> not my favourite job, currently looking into a chop saw/hard disk cutter arbour for stainless! either that or its going to a hacksaw job:(
swage/bead alu intercooler pipes.
I/C mounting bracket + weld outlet/inlet back on.
IACV spigot on boost hose.
recirc spigot on air pipe
