Actual 5-lug swap info.
- Evo_Spec
not sure if this was posted here yet or not but the pile did an actual "how to:" for us! (well, everyone)
http://www.clubprotege.com/forum/showth ... MX3-Escort
- BornSticky
Re: Actual 5-lug swap info.
so do the brakes have to be swapped as well obviously the rotors do but pads and calipers?
im really wanting to do this cause my rims are starting to get pretty ugly looking and have a 16" pair of rims i was gonna sell that were 5 lug but if this conversion actually works!
92 Mazda MX-3 KL-ZE Curve Neck, Probinator ECU, Full 2.5" exhaust with headers,  cai, performance radiator, millenia alternator, 5spd, excedy stage 2 clutch, MTX 12" sub sony explod D series 600w amp, pioneer 260w deck, kyb on dropzone springs, HEI mod.
#5389 to join MX-3.com
- Evo_Spec
i actually have no idea but if i was to guess you use the rotors and calipers/pads from the donor since he says:BornSticky wrote:so do the brakes have to be swapped as well obviously the rotors do but pads and calipers?
meaning the stock line will go to the new caliper, no?The Pile wrote:6. Install brakes. Stock brake lines work.
- AaronTietje
Here are some actual pics of the probe front hub modified to fit our struts next to my old mx-3 hub.
I also have two other sets of brackets to mount these calipers to the probe hubs....
We all want to be fast and look cool.  Cool changes but fast never does.
						- BornSticky
Hmmmm I donno if I wanna bleed my brakes just for another lug.
- MrMazda92
How about for Mazda6 big brakes?
  5 lug potential is pretty badass...
- Evo_Spec
lol, bleeding your brakes is super easy IMOBornSticky wrote:Hmmmm I donno if I wanna bleed my brakes just for another lug.
unless you have SS lines, just clamp the brake line so the fluid doesn't come out, then you have less to bleed
- marcdh
Or live in Europe and just bolt on the 323F BA parts...  For once a cheaper option in the UK
							AZ-3 1498cc Turbo!  EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
View Worklog
View Worklog
Do not do this, get a vacuum bleeder and do it properly. Brakes aren't one of those things to not do correctly.lol, bleeding your brakes is super easy IMO
1994 MX-3 RS
B6 goodies for sale:
viewtopic.php?f=2&t=66333
- DeadMaker
But still it's rare part this model..marcdh wrote:Or live in Europe and just bolt on the 323F BA parts... For once a cheaper option in the UK
Black Mazda Mx3 Rs 1997 B6DE
