I can never seem to get the coolant hoses and rubber fuel lines in and around the engine off without cutting them and replacing them they either wont slide off or they are melted right on (which seems to be the case with coolant hoses...)
I had this problem when i swapped in my klze last year and again yesterday i pulled a DE with a friend and had the exact same issues
is that normal? or am i missing some easy obvious trick? Like i've seen fuel line pulling tools but i've always thought those were for quick disconnect type lines and not so much the hose and clamp kind of lines?
I always try and twist first, then pull. Once you free up even a small section of the hose, you can soon spread that free section with a twisting action. Worst case scenario, mole grips to twist a little.
AZ-3 1498cc Turbo! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt Mx-3 2.5 V6 Turbo 291 BHP 251 lbft @ 8psi - Retired due to rust and back at uni View Worklog
very normal.. Over time hoses glue them selves to what ever they are seated on... The longer its been installed the more of a b---- it is to get it to break free... As mentioned twist the hose first... Use plyers if needed just take care not to cut the hose... Also if it has spring clamps, replace them with some better clamps.. Once you crack a hose loose with a spring clap and go to reinstall it with the same spring clamp there is a good chance it will leak...
If I have to use pliers on a hose I always try to grip it over the pipe that it is installed on, not just on the hose itself. The hose almost always tears when I do that.
The fuel rails are tougher because the bubble on the pipe is larger than on other fittings becuase it's pressurized. Be real careful with the fuel lines.
2004 Honda RC51 --- Lost forever to some theavin' bastard My Worklog My feedback thread Never attribute to malice that which can be adequately explained by stupidity.
Those r good for the clamps ^^^^^^. what i do is take a set of plyers with the little groove in them for bolts n stuff and grip the hose with that then twist n wiggle a bit and itll break loose. then u should be able to just pull n wiggle it off. make sure the clamp is off the spout or w.e. And that theory on your spring clamps isnt true... ive reused them on my k8 and my ze when i did the swap, i have 0 leaks. and never have had a leak from one of them.
I made a habit of lubricating hoses off of a little oil from the dipstic & everytime I have to go back to a hose its saved me time & knuckle skin
1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
I do the pliers thing as well squeezing (kneading the hose) and twisting and I also found inserting a small common screw driver between the hose and pipe works. Oh, cussing at the hose helps too.
Daninski wrote:I do the pliers thing as well squeezing (kneading the hose) and twisting and I also found inserting a small common screw driver between the hose and pipe works. Oh, cussing at the hose helps too.
To a T, exactly what I do.
Well, except for that PITA 90 degree elbow on the back of the Milli IM... I cut a portion of that evil SOB off, so I can remove it without scaring my neighbors away with my cursing. Deleted the EGR too, for the sake of convenience... That ridiculous threaded nut for the exhaust port was taking more time than anything during manifold removal.
