I have to ask, where do you source rear clears? I haven't seen any... I know fronts won't fit in the back, I tried that already.
There's only one version of the clear markers. For the rear bumper you have to flip them upside down...RobMinhas wrote:I think they come from a Miata although I'm not certain on the year.MrMazda92 wrote:
All you have to do is shim the top edge or bottom, the opposite side that is sticking out. I cut a vacuum line in half and used that, they fit flush after that.MrMazda92 wrote:Mark, they stuck out closer to 4 or 5mm when I tried last week.
Words to live by right there!Ryan wrote:Management unlocks all the potential of your modifications...
I never thought I would see the day!Ryan wrote:If you're a busy-ish person, but a pre-assembled. Its worth it.
