Power Steering cooling pipe
Dragonwight
Post by Dragonwight »
Like most MX-3`s the return cooling pipe for the power steering on my MX-3 has had its day. No way am i paying what they are asking for an OEM replacement part. So i took it to my local garage who are quite handy with pipe making etc and they said they would simply cut the pipe off and stick a rubber hose on.
Apparently they have done this on a few MX-3`s with no ill effect. Has anyone else done this and found it was ok? I could get length of copper pipe and do it myself but dont have the means to create the ends of the pipe.
Re: Power Steering cooling pipe
I spoke with a knowledgeable service manager at Mazda about this and he advised against it. If there's a wreckers near you lots of cars have very similar pipes Hyundai being one of them. Grab a similar pipe and bend it to fit. There is no need for any special end just slide the rubber hose on and clamp it like Jed.
MrMazda92
Post by MrMazda92 »
Daninski wrote:clamp it like Jed.
LOL!
I don't think I've seen this reference before... Total nostalgia though, thanks for that!
mikeinaus
Post by mikeinaus »
ive got a hose i could sell you but shipping might be a killer...
Dragonwight
Thanks for the offer i think shipping might be a tad expensive as you say. Ill just make a pipe up I can get 3 metres of 10mm copper pipe for £10 then just make like a hill billie.:-)
When I put a new rad in my other MX3 it had provisions for an automatic trans so I was going to connect my PS to it.
wagZE
Post by wagZE »
Am I the only one who doesn't run power steering?
1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
PS WTF!
Post by Josh »
You are Wag :)
On the AWD RS I have used a ford probe oil cooler for the PS cooler. works just fine. I was planning on using an ATX rad and use the cooler in it for the PS.
I was wondering about using an RS cooler vs the GS cooler anyways as the RS cooler is so much smaller. I do not think that there would be any ill effects.
