control arm bushings?????
- fredroponics
well i need new control arm bushings and im having trouble finding them....any places in mind or is there another car i can match up the bushings....my mx3 is a 1.8 v6....please help
93 mx3 1.8 v6...under construction
Re: control arm bushings?????
I called the mazda dealership and they have all the control arm bushings
MazdaSpeed used to make some, could check with CorkSport. SRD made some too, some people didn't like them cause they were noisy, but they worked well. CorkSport may have some left if you're lucky. Did Wyt make CA bushings?
Yeah I think there were Wytbushings for the front LCAs...
Worst case you could go to the junkyard and just pull the entire LCAs. Yeah they would be old but maybe better than what you have? I just did this Sunday and it was like $40 bucks and about an hour of time (because I had to saw through the endlinks).
we share the same control arms as other BG chassie cars there just longer right? so why not use the zx2 ES control arm kit?
