 . Car- mazda mx-3, engine 1.8v6.
  . Car- mazda mx-3, engine 1.8v6.The thing is- when I turn the ignition key, nothing happens. All the dash lights just go out(like there is no juice). Starter is not kicking in, instead there is some wierd clicking noise somewhere in the panel(sounds like behind a radio) but it doesn't click every time (only sometimes,very rare). I can't start the car with ignition, only if someone towed me.
I was really convinced about starter itself, but then I browsed around google, and it seems there is some kind of starter relay. Is it hard to get to it and repair, or maybe just bypass it? This problem happens very rare(I can start my car like 10x times a day,whole month, but then -one time it would just be dead).
What I did myself(for you not to think I don't do anything myself)
1- charged the battery(it is brand new, but you never know).
2- Checked the starter wiring, to see if any wire has become loose (everything was great,not even a little bit of corrosion).
3- Checked the ignition wires(with multimeter,to see if maybe the electricity is going where it should- all good there).
Your thoughts on this matter would be appreciated, because I can't trust my car anymore since I must get in with a though-''maybe it won't turn on this time''.
Thanks again!
 . If it would be, than it would be obvious I think. Is there any way to check it?
