94 mazda mx3 5-speed idle air sensor
pdoan_98
Post by pdoan_98 »
All,
It appears my car idles real low when I am at a stop. I was told to check the idle air sensor. Can somebody tell me in "poor man" terms where this is located. I'm not very mechanically inclined.
Thanks for the help.
Pat
Re: 94 mazda mx3 5-speed idle air sensor
Can we have a little more info, what engine you have and what rpm is it idling at and does it stay at that idle after you stop or just when you first stop. Cheers
pdoan_98
Post by pdoan_98 »
Sorry for the lack of info.
I have a 1.6 cylinder. IT usually is idling real close to the 0 on rpm gauge. When I start, it somtimes has a slow rpm increase and then all of a sudden it will surge and pick up speed.
I had for about 3 years. I put a can of fuel injector cleaner in the other day. I am going to do a tune-up this weeked.
jeffs93toy
Post by jeffs93toy »
are there any cel lights?
pdoan_98
Post by pdoan_98 »
cel - check engine lights? no
Ryan
Post by Ryan »
No such thing exists by those exact words. We have an idle air control, but no sensor.
First thing to do is check the intake tube that looks like an accordion for cracks, that is the #1 cause for issues like yours.
pdoan_98
Post by pdoan_98 »
Thanks for help. I'll check into that....Is that something that is easily replaced and pretty inexpensive?
Ryan
Post by Ryan »
Depending on where you live, I'm sure a member could get one to your door for $20.
pdoan_98
Post by pdoan_98 »
This might sound like a dumb question...Where is the intake tube located? I'm not a car guy.
THanks for the help.
DeadMaker
Post by DeadMaker »
pdoan_98 wrote:This might sound like a dumb question...Where is the intake tube located? I'm not a car guy.
This is what what Ryan says.
http://www.google.gr/imgres?imgurl=http ... A&dur=1493
I have the same problem too.Not in this condition but it has a leak.Any tips for temporary solution?Cause i don't have the money now to buy it new.Possible to fill the crack with silicone?
Black Mazda Mx3 Rs 1997 B6DE
jeffs93toy
i dont see why a good bead of silicone wouldnt seal it up even for a temporary fix.
cWs306
Post by cWs306 »
cold air intake. there cheap as hell off ebay, might not get some high end filter. but itll do the trick. and it looks cool 8)
DeadMaker
Post by DeadMaker »
You only refer to the pipe?
Cold air intakes filters works better on turbo applications.In atmospheric engines like b6de it would probably do more bad than good..Except from better noise.
Ryan
Post by Ryan »
:2thumbsup: for Deadmaker.
first of all, excellent picture of exactly what I mean.
Also, he's right, but no one likes to talk about it. B series intakes are actually of excellent design(although it doesn't seem that way based on intuition). Had an engineering friend actually legit discover that the best intake setup he could make was the stock one, with the bottom of the airbox cut out.
I do it for noise and shinyness...
DeadMaker
Post by DeadMaker »
Ryan wrote: Had an engineering friend actually legit discover that the best intake setup he could make was the stock one, with the bottom of the airbox cut out.
So we should take the chance and cut it out? :D
But in this case isn't there a chance the fuel air ratio to become more lean?
What about changing the oem filter and putting k&N?
