projector halo?
kudkudniyog
projector halo?
Post by kudkudniyog »
Has anybody dissected a projector headlight to change a bad halo bulb? or maybe upgrade to something brighter.
Calg_93GS
Re: projector halo?
Post by Calg_93GS »
kudkudniyog wrote:Has anybody dissected a projector headlight to change a bad halo bulb? or maybe upgrade to something brighter.
someone can correct me if im wrong, but im quite certain that the halo's light source is just an LED, with a bit of research im sure it wouldn't be too hard to source out a LED with a higher lumen then the stock one.
mikeinaus
Re: projector halo?
Post by mikeinaus »
yes they are leds. there are 3 or 4 leds that plug into the back of the housing by each halo. they should be pretty easy to just pop in and out.
Return to “Appearance”
