Alternator belt woes...
Dark_Rider2k3
Post by Dark_Rider2k3 »
Okay so i'm having this.. odd issue... not odd for me as I always have stupid crap going on (i swear cars hate me =(...)
The issue is that I keep burning off alternator belts. Plain and simple. I've been through 3 belts in a year. (my third belt I smelled it burning today so I know it's going to burn out). I have checked my tension numerous times and I just can't understand why..
The alternator charges fine up until the belt starts to burn.. around 14V charging.. and the water pump works fine, no leaks, and spins freely. Keeps the engine nice and cool. When I start to smell the belt burning the alternator drops down to 12V.
In case you didn't know, this is the EGT BP with the V-ribbed belt.
youdirtyfox
Re: Alternator belt woes...
Post by youdirtyfox »
Do all the pulleys spin freely/aligned?
rubber build up on the pulley?
worn woodruff key?
could be alt. on the way out freezing up...
Dark_Rider2k3
youdirtyfox wrote:Do all the pulleys spin freely/aligned?
worn woodruff key?
Pulleys all spin freely. What's the best way to tell if they are aligned? And worn woodruff key? You mean the piece that holds the balancer on?
