Off a Minari kit car wich uses MX-3 headlights, and quad headlights
are an option, molded directly off an MX-3 headlight
you can seeing were im going with this cant you:lol:
same here, i was looking it up on google and thought it looked like a miata with our headlights and signalsNd4SpdSe wrote:OMG this is true! I've never seen this before!
   I thought it was a miata at first as well...
its quite a rare kit car over here i think .Mooneggs wrote:how is this the first time we are finding out about this?!
yes CAI options for sure!
wow man nice touch on those!PATDIESEL wrote:Good luck- it is not likely going to be easy or cheap. I built these
a few years ago from scratch. The materials I messed up trying to get it 100% added up, but the projectors alone (Hella 90mm) were pretty pricey. http://www.rallylights.com/ is a great place to get the lights and a good resource if you have a very specific question.
The biggest issue I would research first is how to mount the lamps to the housing you pictured above. Hella, and most others, use a minimum of 3 mounting points. You can get away with 2, but you need the housing to be pretty aimed already to do so.
