Timing Belt/Water Pump
Eunos 30X/Presso/Autozam AZ-3 Discussions
Ribsmasher-au
Post by Ribsmasher-au »
Hey guys i currently have a 93 30x i just had a awfull time changing the water pump i had to remove the timing belt to get the new one back on and did not mark the belt or anything (i know im stupid) was just so frustrated with all the crap i went thru but anyway i got the belt back on with great effort without any of the gears moving i hope but anyway the car won't start does not seem like it's firing at all the moter just turns it has spark etc could this be due to the way the timing belt went back on? is there anything i can do to fix this?
bbunkerc397
Re: Timing Belt/Water Pump
Post by bbunkerc397 »
Your cams are out and you will have to realign them to the crank, there is little arrows on top of the heads and little lines on the cam gears, make sure their lined up and the crank pulley has similar marks that you will have to check as well. Your in a lot of trouble did you consult your shop manual? There is very detailed instructions in the factory shop manual on doing timing belt installation I did it when I put my ZE in and it was quite tricky.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
Ribsmasher-au
I had no instructions at all, i only just found this forum so had no guides on how to do this. But im guessing i will have to pull it all apart again (cry) reason for doing it myself is the local workshop was going to charge me around $1200 to change the water pump which is only a $100 part.
bbunkerc397
It's a lot of work that's why they charge 1200, well make sure all the marks are lined up and you should be OK. Also there are a lot of forum members here that are probably more knowledgeable than I am could walk you through this.
Ribsmasher-au
Believe me i see why they charge so much now would of been a bit easier if the engine was out my hands are cut everywhere from working it such a small space.
bbunkerc397
I would have dropped the engine.
Ryan
Post by Ryan »
bbunkerc397
You see there you go.... :D
Ribsmasher-au
Cheers guys i just checked and it all lines up to the marks i was very carefull when putting it on not to move any of the wheels but it still shows no sign of starting? The belt is very tight as i could not work out the tensioner (before i found this forum) could that affect it?
Ryan
Post by Ryan »
Remember all your plugs?
The car will start if you're just a few teeth out.
Did I miss the intro thread???????????
Ribsmasher-au
Yeah all the plugs are in everything is hooked up it's got me stuffed
Ribsmasher-au
I will do a intro shortly just running back and forward to the car my mrs wants to kill me as it's not running at all at the moment, seems like a great forum we only just bought the car around 3 weeks ago for my mrs she is going to do it up i myself drive a prelude but was falling in love with the mazda till i ran into all this trouble.
Ryan
Post by Ryan »
If it ran before the timing belt, but not after, you did the timing belt wrong.
Ribsmasher-au
Yeah it has to be, are the marks on the valve covers or the actual block? Also if i get the engine to top dead centre will the bottom pulley be lined up and just adjust the two cam ones? only asking because i dont have the tool to remove the bottom pulley.
Return to “Eunos 30X/Presso/Autozam AZ-3”
