92GS parts car (Canada)
krusty approved
Re: 92GS parts car (Canada)
Do you still have the center console/armrest?
Mastirmynd
I need the need the Gauge cluster trim, and side AC vents, the black ones, i saw a white set on your site too, but i need black.
Build A Man A Fire, He Will Be Warm For A Night. Set A Man On Fire, He Will Be Warm For The Rest Of His Life.
<img src="http://www.bareend.com/mazdaspeed.gif" alt=" - " />
Well I do have the plastic piece that goes around the guages, as for the vents I only have the white ones but those you can easily change with a little black Vinyl spray.
Krusty- I have the armrest but its in beige and the top lid has seen better days.
bikeguy18974
Do you have the rear most belt tensioner assembly? I believe its the PS one. Actually all i need are the threaded bolt that does the tensioning, the part thats moves up and down to tension the pulley, and the 17mm nut piece that holds the pulley to the tensioner.
I have but I cant remove untill I pull the engine. Car took a hit on that side craming the body to the engine. sorry
Technica
My 96 just had a nice encounter with a telephone pole... parts request is in the mail.
Turbo
Hi,
sorry to hear about your ride, any chance on getting the flywheel and MAF..
thanks
jonathon
jonboy_1@hotmail.com
thanks
jonathon
HEY THERE, IF U STILL HAVE THE FRONT BUMPER ASSEMBLY PLEASE LEMME KNOW OR YOU CAN EMAIL ME AT AIRCALI24@AOL.COM
nope the front bumper is finished
Bradmx32003
What condition are both doors? Dont need windows.
Red 1992 Mx-3 GS, all stock.
Both doors are in as good a shape as a 92 door gets, just starting to bubble up on the window frame. almost everything has been salvaged from the doors IE windows, weather stripping, power. so realy Im just left with the bear doors with handles.
Hi
I'd also be interested in the doors. Is it hard to swap the parts from my doors into yours? (ie, window motor) Is there any rust along the bottom fold where the sheets are welded?
please let me know how much your looking to get if u still have them, thanks
No swaping everything over is a sinch. Theh drivers door is showing signs of rust (small bubling starting to show) Passanger I couldnt see any sings of rust.
PS is Winterpeg AKA Winnapeg?
seneca
Hey Greg ol' boy,
I should be down for that piece in just a little more than a month
But I was wondering which headlight you still have, it must be the passenger side right? What kind of condition is it in? The guy at the body shop MAY be able to buff the scratches out of mine, but if not we'll be in touch.
Tyson
ps- Everyone out there....Endocyc is a great guy to deal with, buy from him!!
Tyson
My Car Domain Page:
http://www.cardomain.com/memberpage/496099
Take a Look, leave a comment, and don't forget to vote.
Hey Tyson That piece is just sitting in my window waiting to be adopted. Liek a puppy really.
As for the headlight, your wrong the drivers side is still in one piece. However if your just in need of the lens I happend to keep that from the pasanger side light since only the light casing was cracked from the impact. Just let me know if/when you need it.
