Cruise Control Woe.
Cruise Control Woe.
My woman's cruise control in her 92 GS doesn't work. The light on the indicator lights up, but when you try to set the speed, it won't work. Is this a common problem and hard to fix? Info, cost, etc are appreciated. <P>Thanks guys/gals!
Re: Cruise Control Woe.
check fuses related to cruise control (if any) and from my experience it sometimes takes a longer press of the button (on steering wheel) than you would expect to activate it.
Sonicxtacy02
the ecu takes awhile to pick up that cruise has been activated. wait 3 secs for the system to activate, then press the button down for a second.
Shaun Newman
I've checked any and all fuses. The indicator lights up when the cruise button is on, but I've held the set button for various amounts of time with no luck. Maybe there's a short somewhere or the actuator is bad. I didn't know if it was a common problem or not. I guess it really isn't. Thanks for the info guys!
SmokyMcGee
mY cruise control never worked.. if it makes you feel any better
i got the same problem!
polak_gino
i thought mine didnt work at first , but then jsut played around and then found out it did work !!!
Tyler17rose
I'm not sure, but i think i read in a post before about this that the little round thing on the passanger side of the engine compartment is the cruise control , and that vaccume line needs to be pluged in for it to work: Heres a pic to make things easier.<p>
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
yeah mine works sometimes but doesn't work others. i think that it may be the set/accel button on my wheel isn't making a good connection because i found that if i push it just right it will work.
92 Mazda MX-3 GS: blaze red, bone stock, and daily driver
86 RX-7 GXL: '94 LT1 V8, 6 speed tranny, scary fast. SOLD
93 Mazda RX7 R1 LS1/6speed... 75% complete
http://www.cardomain.com/id/mattsterrx7" onclick="window.open(this.href);return false;
^link to my V8 swap page
