Please help identify engine noise with video (Fixed)
wohpony
Post by wohpony »
My KLZE is making a noise at low RPM's (under 2k). Its wierd it only does it sometimes but is worse when cold. Please help me identify where its coming from.
Heres a video at idle:
http://www.youtube.com/watch?v=UN96sGrKD90
Heres a video with slight rev:
http://www.youtube.com/watch?v=98FKD5slf4Q
1993 Mazda MX-3 GS KLZE
Re: Please help identify engine noise with video
Timing belt tensioner needs replacing?
solo_ryder
Post by solo_ryder »
Sounds like a timing belt tensioner. Usually as you rev the sound goes away, that is because the belt has enough momentum to loose the slack and stop the slapping of the belt all over the covers. Saying that it is worse when cold is also another sign as the oil that is left in the TBT is sluggish and the piston wont move as well until it is warmed up
Since you already have the cam gears showing, check to see if there is slack in the timing belt in any area, that is probably a indication the tensioner is shot.
Inodoro Pereyra
Post by Inodoro Pereyra »
My money is on the friction gear springs. :shrug:
Diogenes of Sinope.
Ryan
Post by Ryan »
way too loud and fast for FGS. tbelt tensioner.
Inodoro Pereyra
We'll see...
Diogenes of Sinope.
Inodoro Pereyra wrote:We'll see...
Oh man, that was a real b*tchin come back. :P
Inodoro Pereyra
I knew you'd like it. :lol:
Diogenes of Sinope.
MrMazda92
Post by MrMazda92 »
It could be either, or both. You guys probably figured this already, but since the timing cover is off the sound is less muffled. Certainly not my area of expertise though.
wohpony
Re: Please help identify engine noise with video (Fixed)
Post by wohpony »
R2 the timing belt tensioner and now its almost to quiet :D
Thanks so much for the help guys!
Inodoro Pereyra
Looks like I was wrong after all...
Glad you could get it fixed. :D
Diogenes of Sinope.
Inodoro Pereyra wrote:Looks like I was wrong after all...:D
First mistake in 45 years, not bad my friend. :D
Inodoro Pereyra
Daninski wrote: First mistake in 45 years, not bad my friend. :D
:lol: :lol: Believe me: it's NOT the first one... :lol: :lol:
Diogenes of Sinope.
hgallegos915
Post by hgallegos915 »
LOL I had the same problem, I could have sworn I posted on this thread but I guess not.. maybe a similar one hehe.
-hec
