I diglo gauges
I diglo gauges
So I Got my hands on a cluster with indiglo gauges installed, I just installed it on my lunch, everything works only problem is my temp gauges reads hot all the time....is there a chance the cluster is bunk?
						- solo_ryder
Re: I diglo gauges
What you mean all the time? As in when the car is off to? Or all the time when the car is warmed up?.. Which wouldn't be all the time.
Anyways I'm guessing the guy who installed them (probably you) twisted the heat needle to much when putting the gauge face on so no its reading innacurate.
Re: I diglo gauges
I bought the cluster with the indiglo speedhut face preinstalled, when the car is cold it's right at the c not under the sweep like it normally is and when warm it sits above the h. I believe it's just the needle position that's screwed up, can I just pop off the needle and try it in a different spot or does it have a key way?
I drove home with no illumination cuz I don't wanna fully install it just to have to rip everything back up.
- solo_ryder
Re: I diglo gauges
You can try to pop the needle off but you will probably break it. Your best option would be to installed the gauge faces over another cluster.
The temp needle is twisted, its connected to a thin metal shaft, and that is what is twisted.. so if you try to twist it back it may break, and if you pull it off it may also break as the strength has been compromised.
Re: I diglo gauges
Well I do have my original cluster so I may pop off the needle and see if I can get it back, if it breaks I'll use my original, just wanted to see if it was possible.
Thanks guys
						Thanks guys
- Ryan
Re: I diglo gauges
the needles are not meant to come off...
Try twisting the needle to its proper position when the cluster is OFF. Like, try to compensate for how it is off.
If its flucked, there's no harm in trying.
Re: I diglo gauges
YA SO TRYING TO FIX THE TEMP GAUGE BUT ITS DEFINETLY FUBAR'D I'VE WIRED IN THE INDIGLO ANYWAYS CUZ IT SUX DRIVING RUSH HOUR AT NIGHT WITHOUT DASH ILLUMINATION, AND I'LL EVENTUALLY SWAP BACK TO MY ORIGINAL CLUSTER. INDIGLO IS NICE OHHHHHH AHHHHH LOL.
NOW JUST NEED TO WIRE UP MY TEMP,VOLT AND WIDEBAND.
I THINK ITS TIME I START A WORKLOG.
- solo_ryder
Re: I diglo gauges
ZOMGGG!!! SOOOO EXCITING!!mx3matt wrote:YA SO TRYING TO FIX THE TEMP GAUGE BUT ITS DEFINETLY FUBAR'D I'VE WIRED IN THE INDIGLO ANYWAYS CUZ IT SUX DRIVING RUSH HOUR AT NIGHT WITHOUT DASH ILLUMINATION, AND I'LL EVENTUALLY SWAP BACK TO MY ORIGINAL CLUSTER. INDIGLO IS NICE OHHHHHH AHHHHH LOL.
Re: I diglo gauges
you may not be excited but i sure am lol.
i've said it before the reason for capitals is my programs i use at work require capitalization, thanks for the sarcasm tho.
- solo_ryder
Re: I diglo gauges
YWmx3matt wrote:you may not be excited but i sure am lol.
- Hoodzy
Re: I diglo gauges
did you get them for free? or you get your money back!?
1995 Creek Mica Blue GS
				Mnemonic
Re: I diglo gauges
Yea I work in after effects at work a lot and i have to keep caps on to keep the preview screen deactivated while i render... I've become a pro at typing with shift down lol
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
