K8(In the car), KL project in the shop. I wouldn't do the K8, except it's getting worse... I fear it may be covering up other noises too, and I'll be needing that engine for the next few months at least.marcdh wrote:Why 4? Only 2 cams have the friction gear spring. Or you doing two cars?
How to replace friction gear springs W/O removing the Tbelt
- MrMazda92
Re: How to replace friction gear springs W/O removing the Tb
- marcdh
I transfer mine when I change cams, you could just change them on the k8 and swap them over when you do the KL swap.  Bit annoying if you want to fully prep the KL for swap though.
							AZ-3 1498cc Turbo!  EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
View Worklog
View Worklog
- MrMazda92
That's a good point, and I would be doing the same if I didn't have plans for the K8 as well. I'll be putting it in a clean shell, if I ever find one...
- Ryan
Putting a K8 BACK INTO an MX-3 is a waste of time IMHO.
Would be a sweet motor for a 323 though.
- MrMazda92
It depends on the purpose of the car. For this, it's far from a waste.Ryan wrote:Putting a K8 BACK INTO an MX-3 is a waste of time IMHO.
- BornSticky
I would just weld it then grind it well so the socket still fits,  worst thing happens is it doesnt work and you have to fork out that money anyways...
							92 Mazda MX-3 KL-ZE Curve Neck, Probinator ECU, Full 2.5" exhaust with headers,  cai, performance radiator, millenia alternator, 5spd, excedy stage 2 clutch, MTX 12" sub sony explod D series 600w amp, pioneer 260w deck, kyb on dropzone springs, HEI mod.
#5389 to join MX-3.com
- Inodoro Pereyra
Welding on the spring would weaken the steel. You'd end having to take it all apart again pretty soon...BornSticky wrote:I would just weld it then grind it well so the socket still fits, worst thing happens is it doesnt work and you have to fork out that money anyways...
Diogenes of Sinope.
Diogenes of Sinope.
- MrMazda92
So... I'm completely unable to loosen the 17mm bolt on the cam sprocket
  As in two strong guys with lots of leverage won't break the b**ch. Any thoughts guys? I'm thinking impact gun. Also, the cam cap closest to my disty was broken when I pulled the forward VC. Another bonus... I can't drive her until next week at least...
- MrMazda92
103 ft/lbs is what my Chilton manual says the sprocket bolt should be torqued to... The b**ch was torqued to more than 200 ft/lbs
  The last person to do a timing belt on this car should be hung.
- Ryan
Torque on doesn't equal torque off, never.  When you're torquing down a bolt you're working against the kinetic friction, when you're taking it off you're working against the static friction, which is always greater.  Plus corrosion effects....
But yeah, they're tight bastards.
- MrMazda92
I'm aware of that Ryan...
  I broke 2 ratchets using a 4 foot long bar extension, with a 220 lb helper on the bar. I held the crescent wrench on the hex. portion of the camshaft. The 3rd ratchet slipped twice before it FINALLY broke free. I had to lever myself against the underside of the front end to hang on with the torque applied to that 4 foot extension. Trust me, it was tighter than it should have been. The worst part, I couldn't get an angle with an impact gun, so doing it by hand was my only option
- Ryan
Surprised you didn't break the cam.  They're just cast.
- MrMazda92
They're also held very sturdily in place by the caps, as well as the other cam in the head... You make a valid point though, I'm glad it finally gave when it did.Ryan wrote:Surprised you didn't break the cam. They're just cast.
you shouldnt even bother looking for an alternative, some things you can safely modify and some projects its just safer to spend the money on the RIGHT part. its less then 100 bucks anyways!MrMazda92 wrote:Hmm. Point taken, my concern with welding is the possibility of mangling the nut so much that it wouldn't fit in a socket. I just hate that it'd cost me $40 for something so simple! The washer is reasonable(ish), but I need 4. I can grind the nut, but 4 washers at $13/each is overpriced to say the least. I'll figure something out, but if anybody knows an alternative, please let me know!
like mario(andretti) said in an stp commercial years ago. "you can pay a lil now....or a lot later"
- MrMazda92
On certain things I would agree... this I wouldn'tmx3matt wrote:you shouldnt even bother looking for an alternative, some things you can safely modify and some projects its just safer to spend the money on the RIGHT part. its less then 100 bucks anyways!MrMazda92 wrote:Hmm. Point taken, my concern with welding is the possibility of mangling the nut so much that it wouldn't fit in a socket. I just hate that it'd cost me $40 for something so simple! The washer is reasonable(ish), but I need 4. I can grind the nut, but 4 washers at $13/each is overpriced to say the least. I'll figure something out, but if anybody knows an alternative, please let me know!
I bought the FGS replacements from the stealership, as they were cost effective at ~$13/each; but I didn't pay $26/piece for the nut, which I modified at home with a grinder in ~5 minutes(counting setup and cleanup)
