Mr_Shortys Worklog- 1991 Presso AWD
Mr_Shorty
Post by Mr_Shorty »
So, I'm finally starting a worklog for this car. I've got the AWD Protege rear end to start mocking up mounting points in my shop. Below are pics of the AWD car I bought and cut in half to save room in the shop. I'm in the process now of cleaning up a spot to actually do the work. I will post info and pics as I get more done.
Elected Dictator
1991 Eunos Presso AWD build starting winter '10
Ruby Mica
1992 Eunos Presso special build starting ???
Ruby Mica
1992 Familia GTR AWD donor car
Black
Evo_Spec
Re: Mr_Shortys Worklog- 1991 Presso AWD
Post by Evo_Spec »
this seems like its going to be an epic worklog, starts off with a car cut in half!
will be following this thread for sure!
AaronTietje
Post by AaronTietje »
This is very interesting, looking forward to this build. :D
I was going to ask why you don't need the front half, but than I saw the auto shifter. Still, you cut the drive shaft, don't you need that?
One thing that I've been curious about for years; what do they do for gas tanks in those things, and why can't those be used on the Mx3?
Mr_Shorty
Post by Mr_Shorty »
I didn't cut the drive shaft. Only the exhaust and brake/fuel lines. I saved the shaft and fuel tank. I'm hoping to use the stock fuel tank. The fuel tank is one solid tank, like the MX-3 tank, except it has a U shaped bend to accomadate the drive shaft. It also has two fuel pumps. One to provide fuel to the engine, the other to pump fuel from one side of the tank to the other. Because of the U bend in the tank, fuel would be trapped on the passenger side of the tank when it is emptied from use.
Elected Dictator
Ruby Mica
Ruby Mica
Black
The exhaust run in the channel with the driveshaft? I'm going to say not it just ended up that way after it was halved, eh? I just saw the cut pipe and thought you cut the driveshaft
Oh, that's a neat fuel system
I never thought about a fuel tank accomodating the drive shaft... makes sense though! Sounds like a great project!
Post by Josh »
The tank should fit, I never mocked it in place when I did my swap. You will probably have to cut out access panels for the pumps, or replace the whole seat section. I was able to fit my exhaust through the stock mx tunnel. Good luck looking forward to seeing the progress.
