TIming belt
Brooklyn23
TIming belt
Hey My timing belt broke and I wanted to know if anyone can send a right up on how to change it
- Evo_Spec
Re: TIming belt
it'd really help if we knew what car/engine you have, assuming because you posted this in the 4cyl area that you have a 4cyl? SOHC or DOHC?
while your replacing your belt i recommend you replace your water pump as well, and if you really want to go the extra step you can replace the cam and crank seals (assuming your not gonna be dumb and is buying a timing belt component kit and not JUST a belt, in which case i recommend getting the kit with the idler and tensioner)
if you have a DOHC this will help a lot, even if you have a SOHC it'll give you a good idea
http://mx5unleashed.com/tech/timing-belt-mx5.html
Brooklyn23
Re: TIming belt
o sorry its a 92 sohc 1.6L
- Ryan
Re: TIming belt
Its easy as pie. Plenty of room to work on that motor. The timing is fairly intuitive.
http://www.mx-3.com/manuals/showimg.php ... B1-012.gif
Brooklyn23
Re: TIming belt
i am having trouble taking off the belt that on the power sterring pump how do i take off the belt and is the bolt for the crank pully hard to take off i ask because i am changing the timing belt on the street and its cold i have no choice because the old belt broke . the diagram is helpfull the belt on the power sterring
Brooklyn23
Re: TIming belt
- Ryan
Re: TIming belt
http://www.mx-3.com/manuals/showimg.php ... B1-006.gif
at the bottom of that page it shows how to remove the alternator belt. The alternator itself is the tensioner.
http://www.mx-3.com/manuals/showimg.php ... B1-007.gif
at the top of that page is the PS pump. the PS pump itself is the tensioner.
Crank pulley is 200 ft lbs, lots of guys jam their breaker bar against the A arm or ground and tap the starter to get it off.
- umcamara
Re: TIming belt
An impact gun makes the crank bolt a non-issue if you have one...
- Ryan
Re: TIming belt
But just cause you use an impact doesn't make it fast... eh Curtis?
On that note, I got an impact for christmas
- umcamara
Re: TIming belt
Correct. It's a proven fact that Ryan works twice as fast with hand tools than I do with air tools.Ryan wrote:But just cause you use an impact doesn't make it fast... eh Curtis?
Dark_Rider2k3
Re: TIming belt
I heard Ryan can buzz off lug nuts with hand tools faster then an impact
- umcamara
Re: TIming belt
I heard Ryan once ate a giant... whole... without even chewing...
Re: TIming belt
That's funny because giants are big.
- Ryan
Re: TIming belt
Now you're just getting mean.
Re: TIming belt
Some say he naturally faces magnetic north and that all his legs are hydraulic
Some say His testicles are made from Titanium and that his under-pants are carbon-fibre
Some say that he's a C.I.A. experiment that went wrong, and that he only eats cheese
All we know ... he 's called Ryan
