hahaha i think the first part of our posts should really be in the 'off topic' section hahaha... or is hair related to the electronics of mx-3s somehow??
haha yeah... i did forgot to take pics/write anything down when I took mine apart... but i did take photos of it when I put it back together!!
So here goes... the "HOW TO: fix your passenger side window switch using stuff from the kitchen and some screwdrivers - a guide for complete and total noobs."
So first, you take out the screw holding the door handle in place:
then take off the backing of the handle by pulling on the handle and then the backing as well:
And then remove these 4 screws in these pics:
Then, carefully run your fingers around the inside edge of the door card, to loosen/free the clips that hold it to the door. Be careful not to pull too hard, or you'll break the clips. and thats bad.
Then you lift up the door card, which should be loose from the door except at the top. Once you've lifted it up from the door, pull it away a little from the door, then unclip the elec window switch here:
Now you can completely pull the card away from the door.
To remove the handle to get to the switch properly, undo these two screws:
You should now be able to slide the handle itself out. Now see the black area kinda inset in the white plastic at the top?
We need to press hard in there to pop the switch out. I used a rag wrapped around a screw driver so I didnt wreck the plastic to get this out:
Now you should be able to pull the switch out. The plug can fit through the hole where the switch usually sits. In order to get to the insides of the switch, there are two tabs on each side of the switch (long ways). To pull the switch apart, simply shove one screw driver down each side of the switch like so, and use one to lever it out:
Now this can be where problems can be different. One of my plastic cylinders was broken, so I've just shoved a peice of...
To be continued... I've run out of time!! oops
