How to drop motor in 5 speed transmisson in 94 mx3 and....
hello, i got a 94 AN93 mx3 v6 the 93 is auto 94 5 speed, i  wanna put motor an trNNY out of 94 an put it in my 93, how do i drop the motor an tranny the easiest way
						- Ryan
Re: How to drop motor in 5 speed transmisson in 94 mx3 and..
I don't understand your post at all.
Motor and trans out the top. Get a friend who kinda knows what they're doing.
- solo_ryder
well first you, dskfjkj ie dsdofijenr nosjdfn then ;jfosfnn fsdfpj 34 3elnds p34r then alkjdlkafnn23234234 with a motor hoist then adjfoj  lknf fnf  f f  wepoekrpo fsf
And then your done
						And then your done
- Ryan
solo_ryder wrote:well first you, dskfjkj ie dsdofijenr nosjdfn then ;jfosfnn fsdfpj 34 3elnds p34r then alkjdlkafnn23234234 with a motor hoist then adjfoj lknf fnf f f wepoekrpo fsf
And then your done
You messed it up, it should go like this:
well first you, DSKfjkj ie dSDOFijenr nosjDFN then ;jfosfnn fsdfpj 34 3ELNds p34r then ALKJdlkafnn23234234 with a motor hoist then adjfoj lknf FNF f f WEPOekrpo fsf
lol i love these things
							It only takes a single voice to start a revolution
My god i actually laughed out loud reading this!
- Evo_Spec
i'm pretty sure that's what he tried to say, i've spent some time with some elementary drop out's so that's the best conclusion i came up withspidlemx3 wrote:hello, i got a 94 AND a 93 mx3, both v6, the 93 is an automatic and the 94 is a 5 speed.
i wanna pull the motor and tranny out of the 94 and put it in my 93.
what's the easiest way to drop the motor and tranny out?
anyways, the best answer to your question spidle, is to use this link (http://www.mx-3.com/phpBB3/search.php" onclick="window.open(this.href);return false;) and search it yourself, there's lots of information on how to swap stuff
indeed, 2 options
1) Pull the motor from the top with the trans attatched
2) Drop the front subframe and swap
Not sure which way is easiest.
And spend lots of time converting the auto 93 to a standard.  A least you got something to do now.  Either use our search or Google your questions.  We will help but you need to do some of the work yourself.  Soemtimz yue gyes ar teo mush.
