RUNNING RICH
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
snoopyKLZE
RUNNING RICH
Post by snoopyKLZE »
hey every one i got a problem with my mx3 running crazy rich its a 1992 mx3 with the klze swap curve neck manifold and am running the KL36 ecu i scanned my car and the codes i got where no change in both left and right O2 sensor - Knock sensor - and a EGR code i change both or sensor but i got the same code again aftermarket o2 thow i had to cut and splice the wires i look up the schematic for the wire so i got the wiring right don't know what easl to do am willing to pay to get the problem fix ive been trying to solve it for 2 months know don't know whats gooing on am loacted in brampton On need some help plz thanks. ill pay if i have to thanks
umcamara
Re: RUNNING RICH
Post by umcamara »
I have no idea what you wrote there... Does your keyboard have a comma or enter button? They're usually located on the bottom and right sides of the keyboard..
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
snoopyKLZE
Re: RUNNING RICH
i got a 1992 mazda mx3 with the KLZE swap (curve neck) KL36 ecu cars running really rich i scanned the car and the code i got where no change in left and right O2 sensor Knock sensor and a EGR code. the o2 sensor i bought was an aftermarket one so i had to splice the wires and wire it in the wire is right i got the schematics for the wiring. ill pay to fix the problem if i have to i i got the 1.8 exhaust manifold on the klze looking to by headers if any body got any need help plz and thanks.
MrMazda92
Re: RUNNING RICH
Post by MrMazda92 »
snoopyKLZE wrote:i got a 1992 mazda mx3 with the KLZE swap (curve neck) KL36 ecu cars running really rich i scanned the car and the code i got where no change in left and right O2 sensor Knock sensor and a EGR code. the o2 sensor i bought was an aftermarket one so i had to splice the wires and wire it in the wire is right i got the schematics for the wiring. ill pay to fix the problem if i have to i i got the 1.8 exhaust manifold on the klze looking to by headers if any body got any need help plz and thanks.
Quick clarification, is it a J-Spec ZE with a Millenia curve neck? Or a complete Millenia 2.5?
The KL36 ECU was originally intended for a J-Spec ZE, and I believe the Millenia comes with a KL01 ECU, same as the DE. Wait for verification on that one. As for the rest, you'll need to re-word this part of your question: " i scanned the car and the code i got where no change in left and right O2 sensor Knock sensor and a EGR code."
I wasn't sure if you meant it threw codes or not.
As for the headers, refer to the WTB(Wanted To Buy) Section, here: http://www.mx-3.com/phpBB3/viewforum.php?f=48
Good luck, hopefully a solution becomes readily available to your problems!
snoopyKLZE
Re: RUNNING RICH
thanks for u help so i think it's the 2.5 millenia engine not a 100% sure. I don't know to much about the K engines. I got the car scanned as in i hooked up a scanner to it and the code i got where No change in both o2 sensor EGR and Knock sensor circuit falt. I don't understand why i got a EGR code with the KL36 ECU?
Re: RUNNING RICH
I already gave you some good info but instead of going ahead with it or asking for more help you dumped the thread and asked the same question all over again. You could of changed the title of your original thread if you thought that would help but to discard help that was already offered. ??
Original thread: http://www.mx-3.com/phpBB3/viewtopic.php?f=50&t=75749" onclick="window.open(this.href);return false;
Others would of saw what I already discussed with you and could of built on that.
snoopyKLZE
Re: RUNNING RICH
lol sorry i copyed and paste that question by accident i did what u said my idle is way better but it's still running rich do you think my coolant temp sensor can be bad is that a common thing on the KL engines?
Re: RUNNING RICH
Our engines do tend to run rich. How are you determining rich? Oh and did you check your timing?
What O2 sensors did you use?
snoopyKLZE
Re: RUNNING RICH
it's really rich in the morning it struggles to idle and lots of black smoke. and aslo when it idles lot of popping in the exhaust but when it worms up it's not as rich and it idles ok Know and then it will idle up and down.
snoopyKLZE
Re: RUNNING RICH
i used the bosh O2 aftermarket ones and ye my timing is good.
Re: RUNNING RICH
I'm not a fan of bosch, I prefer original equipment like Denso.
_-Night-Shade-_
Re: RUNNING RICH
Post by _-Night-Shade-_ »
I just took a look at his MX-3 tonight. He doesn't have a KLZE, the heads are KL-101/1A1, it's a DE with a Millenia IM, possibly a Millenia DE altogether since it had no 2nd coolant sensor originally, indicating that it could be a 94+. So that introduces a few issues right away (apart from the messy redneck job of the swap itself which was done by some Honda guy) since he's using the KL36 ECU and it is indeed a DE which means it's supposed to have an EGR passage. The car generally runs fine, it's probably just a bunch of small things like wiring and vacuum.
Re: RUNNING RICH
Post by wytbishop »
His car is just pissed off at his lack of grammar and punishing him for typing like a retard.
MrMazda92
Re: RUNNING RICH
Post by MrMazda92 »
Side topic, my car seems to run a little rich with almost everything stock.
Only tell is light smoke when it's cold, even after the water evaporates. Well, that and the smell.
_-Night-Shade-_
Re: RUNNING RICH
I hate it when people say "my car runs rich, I can see smoke and I can smell it" that means nothing! Unless you have an O2 sensor built into your nose and your eyes can detect tailpipe emissions then don't make any assumptions until you can confirm it.
Return to “Engine Electronics/Tuning”
