Someone f-ing hit me!!!!!
So sum1 scrapped and dented my drivers side lower quarter panel I think. It's right in front of my rear tire drivers sidec it's like they started backing out bumped me with the their bumper and kept going pushing that whole lower half in so how do I take that whole peice off so I can fix it plz help
- Inodoro Pereyra
Re: Someone f-ing hit me!!!!!
Is it too damaged? Can you post a pic?
If it's not too damaged, you can pull it out with a sliding hammer, until you get it as close as you can, and then bondo it.
If the damage is too bad, you will have to cut the part off, and graft a new part in its place. Sorry...
Diogenes of Sinope.
Diogenes of Sinope.
- PATDIESEL
Indoro must have some body work XP, that is pretty much what a body shop would do. Some would reaplce the whole quarter panel, but the rear quarters are kinda tough to replace. Depending on the damage, it is likely a body shop job, not a do it yourself. But, if you are bold practice makes perfect, so give it a shot.
Ya they'll spot weld a piece of rod onto the quarter panel and use that to pull it back out. Avoid using those dent pullers that screw into the metal. Or you can get Inodoro to blow into one of the quarter panel drains and pop the panel out. God know he has enough hot air to accomplish that.
- Inodoro Pereyra
Well, today, an for the next few days, I'm eating pork and beans, so hot air I'm gonna have a plenty...
Diogenes of Sinope.
Diogenes of Sinope.
Beano my friend Beano.
- Inodoro Pereyra
Never. I don't like keeping things bottled up inside...
Besides, that's one of the advantages of being single...
Diogenes of Sinope.
Diogenes of Sinope.
- Dragon1212
my sisters car needed a new quater panel on it definatly a bodyshop job you would need a frame machine so the car can't twist out of shape when you remove the whole side.
Worklog for the Blue One
Worklog for the KLZE
First Car, And My baby... $550 To buy and repair from Write-off... The radio and amp that was in it was worth more than that!!!.
Hunting For a Supra MKIV, but I'll never get one. Still Hunting.
- mitmaks
You don't need frame machine to change quarter panel. Only if your frame was damaged then you'd need to put it on frame machine
- Dragon1212
When we DId my sisters car we needed on mind you we also replaced the whole back end from door to the start of the other quarter panel.
