The project (starting spring of 2010):
1993 RASPBERRY very clean (picked up in NJ)
I immediately put the car under the knife
The engine bay has been stripped down and painted. (BLACK)
INSTALLED: 2.5 95 PGT engine
Fidanza
Stage 3 clutch
Modified tensioner due to the power-steering delete.
Manual 323 rack
G4 intake
94 dash
Stainless headers
DELETED: Power-steering (including lines, pump, etc.)
AC (including lines,pump, condenser, etc.)
Heater-core
All vents (gauges will be installed)
Cruse
AD fan, and ABS relays/wiring
Large amount of vacuum lined due to the G4 intake and front valve
cover
EGR
Charcoal canister
Moonroof assembly
Auto seat belts
Parts sitting around to install.
JDM side skirts
Slim fans
Exhaust Pasesetter
Big brake kit using wilwood, afco, and tenzo R parts
Sparco corsa buckets
N2o kit
Warbro
Milly injectors
Colt cams NA 210 grind
Lsd Trans
SRD front control arm bushings
ELM joint swaybar links
Corksport shifter bushings and 3rd link
Corksport clutch line
Hid kit
Clear/chrome headlights
Factory fuel pressure regulator delete hose and aftermarket pressure regulator
