So i started by taking out the stereo:
Then i took out the pocket after figuring out that it has 2 spring type clips on the sides:
I then got a sheet of acrylic sheet .080" 8x10 and made my plate.
and drilled the 1/2" holes
Bought 2 cheap switches at my local autozone
My prior drilled holes for the wires
after holes are drilled and switches are in (prior to wiring)
Finished
