Okay so a few updates for my weekend.
First, I finished up some wiring i was doing. If you didn't know, my 1.8 bp is a second generation, and the fuel rail harness was totally off. So off, that each INJ was on it's own wire, had an oil pressure switch connector, no FPR connector, and no Water Thermosensor. It did have the VICS, but yeah.. all messed up.
So I made up this diagram:
The diagram moves INJ 1 and 3, and INJ 2 and 4 together, and moves the VICS wire to line up with the VICS wire on the engine harness. It also adds in the FPR + wire, and add the FPR ground wire with the VICS ground wire. I will also be adding in a wire for the thermosensor, and cutting the oil pressure line to use as a water thermosensor ground wire.
So far, I've finished the INJ wiring and moved the VICS. I still have the FPR and Water thermosensor to do.
I also was at the Junkyard the weekend before and got the following:
Rear wiper motor, arm, wiring, washer tank/pump, washer hose/nozzle, and rear mud guards. I painted the mud guards over the weekend just to get them to match each other, but i really need to take them to be professionally painted haha. Get them to match my car. I also Installed the rear washer tank and routed the hose up to above the headliner. I just need the rear hatch and I can install the washer nozzle and hook the hose up to it.
I also gave the car a good cleaning/vacuuming. But more importantly, I got this installed:
