[wtb] 96 mx3 o2 sensors V6
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
azoriankid84
Post by azoriankid84 »
need 2 o2 sensors for a v6 in working condition.
mazdags94
Re: [wtb] 96 mx3 o2 sensors V6
Post by mazdags94 »
You're best off buying these new. Take a look at Rockauto.com, they have some good prices.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD :(
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
azoriankid84
Are they the plug and play or more universal style where i have to match colors and stuff
Ryan
Post by Ryan »
You can get either, but the price difference is like $60 to have the proper plug on it. I like soldering enough, I'm willing to save $120 to spend 20 minutes soldering. Wow, thats like, $360 an hour... to solder... not bad.
Plug and play is the way to go. Check out FAX (daninski) for the proper pn for your 96. Denso are the oem O2 sensors. I bought mine $115 for two delivered to Canada from Rockauto. O2 sensors are exposed to a lot of heat vibration and fluids so make sure if you buy universal (bad idea) your solder joints are perfect and double up on the heat shrink.
PS Ryans cheap so take what he says with a grain of salt. :)
azoriankid84
Would you be able to provide me with a link??
I can't believe I'm doing this, must be because it's Friday. Really you need to familiarize yourself with the available Forums here.
http://www.mx-3.com/phpBB3/viewtopic.php?f=23&t=65706" onclick="window.open(this.href);return false;
the bottom two are only ther to monitor the O2 sensors so don't worry about those. In fact you can disconnect them and nothing will happen.
azoriankid84
Thanks alot. You are officially the man. This is much appreciated.
azoriankid84
just purchased 2 of them. thanks once again daninski.
Return to “MX-3 Related Want to Buy Forum”
