92 Mx-3 1.6L wont start
trife86
Post by trife86 »
Hey guys, was driving my 92 all pefectly, Stalled on me in the road i pushed it off to the side. Cranks cranks cranks with no sign of turning over, checked the code it showed #2, Which i think is the distributor? Would it just die on me like that and not restart? Before this car has been very very reliable and never left me stuck like this
Ryan
Re: 92 Mx-3 1.6L wont start
Post by Ryan »
In the FAQ, http://www.mx-3.com/phpBB3/viewtopic.php?f=24&t=65390" onclick="window.open(this.href);return false;
Code 2 is NE signal, which is indeed inside the distributor.
Thats an odd failure on '92 RS's
trife86
Post by trife86 »
What exactly is the NE signal mean? In the meantime should i buy a new dizzy? I am semi-new to mazda's owned this car about a year and distributor on there looks pretty original
Ryan
Post by Ryan »
The NE signal is the signal that the ECM uses to space the sparks. It should give 6 5 volt pulses for each revolution of the camshaft. It is a hall effect sensor located in the disty.
umcamara
Post by umcamara »
trife86 wrote:Hey guys, was driving my 92 all pefectly, Stalled on me in the road i pushed it off to the side. Cranks cranks cranks with no sign of turning over, checked the code it showed #2, Which i think is the distributor? Would it just die on me like that and not restart? Before this car has been very very reliable and never left me stuck like this
Just to recap...
Cranks == turns over
Runs == fires up = starts
turns over DOES NOT == starts
As you were...
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
trife86
Post by trife86 »
One other silly questiong, Looking on rockauto to buy a new one. They have listed ones with different diameter rotor cams? Does it matter which one i get? I would like to get the cheapest one they sell which rockauto for that one does not list differant sizes?
BTW well engine turns over perfectly but does not fire up
trife86
Post by trife86 »
Well changed the dizzy out today, Easy swap out and all good, Didnt retime it just kinda marked where old one was all good!
