AFAICT this is the long straight KL manifold:
but according to this post:
http://www.mx-3.com/phpBB3/viewtopic.ph ... 79#p219179
The long straight neck manifold shouldn't fit. So why does my manifold not block the master cylinder? It doesn't look like the master cylinder has been moved (or has it?); does that mean my engine is mounted too far forward? If that's the case, could this cause problems or is it just a weight distribution issue?KLZE will have:
-KL31 xxx marked on the heads
-KL01 or KL31 stamped on the camshafts [KL01 for ZE's from Millenias, and KL31 for ZE's from MX-6's]
-Square runners, either curved neck [Millenia] or long straight neck [MX-6] manifold. NOTE: MX-3's can only use the Millenia curved neck manifold, as the MX-6 manifold puts the TB where the master cylinder is.
-No EGR port on the rear exhaust manifold is definately a ZE, though some ZE's have come with EGR.
