guage lights
guage lights
hi all my buddy wants to put blue lights behind his guage cluster but we can't pull out the bezel around the cluster.<BR>can anyone help us? (we've unscrewed the top 3 screws but the buttons on the bottom are preventing removal) thanks for your help.
Re: guage lights
there are two more screws to pull out the plastic cover. You need to drop the steering wheel to the lowest height, if it is adjustable. You need to remove one screw from the steering wheel column plastic covers to get the top piece off. the screw is the one closest to the fuse box. In other words if you sit in the seat and feel under the plastic column it is the bottom left one. once it is out, pop the top of the plastic cover off and you will be able to get to the 2 screws. after that is out, there are 4 more to get the cluster out, I think. <P>that is how I get mine out.
Re: guage lights
tell me if your buddy's lights turn back to green...i put in blue bulbs...for about 3 days it looked somewhat blue...but now its like i didn't even change them.
