Cable speed sensor to electric swap
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
rchie14
Post by rchie14 »
So I bought a totaled car with the hopes of swapping the 1.6L DOHC from it into my 1.6L SOHC but decided not to do the engine swap. Now I read that I can use the transmission off the DOHC engine but I have run across a small problem. My 1993 MX3 has a cable speed sensor and the 1995 MX3 donor trans has an electronic speed sensor. How do I bypass or wire it for my speedo to work in my 93 MX3 ?
rchie14
Re: Cable speed sensor to electric swap
Post by rchie14 »
Deet dee dee moment, looked at the trannys side by side realized the sensors can be swaped put em in putting tranny in now, sorry for wasting a post =)
Return to “Transmissions”
