Everything done by me...
Done so Far:
1. KL-ZE engine swap with curve neck IM
2. 17" ARC Rims
3. Factory side sills
4. J-spec LSD transmission from MX-6, used mx3 axles passenger side and custom JDM Familia drivers axel the fix.
5. Stage 2 ACT clutch kit
6. New shifter linkage
7. Slotted & cross drilled rotors (front and rear)
8. KYB struts front only (still haven't installed rears)
9. New Paint (last fall)
10. Focal polyglass component set front stage, rear stage 4" focal coax, 10" Phoenix Gold XS DVC sub.
11. PG XS6600 6 channel amp running front stage & rear stage / PG XS2500 2 channel sub amp
12. Saved antennae (Installed hidden antenna in headliner)
13. new door rubbers
14. new sunroof rubber seal
15. New moog tie rods
16. New lower control arms with greasable moog ball joints
17. New wheel bearings
18. New Engine mount set
19. New CV's
20. JDM Power folding mirrors
21. OEM New SE seat cover drivers side
22. Center console with cup holder
23. Wytbishop bushings front & rear
24. Eunos Stainless steel kick plates
25. Alpine CDA-7995 high end SQ deck 5V pre-out
26. Alpine SEC-150R with radar sensor & shock sensor
27. 2 Alpine Window module 8341 for window up and window down operation / need 2 more for power folding mirrors & sunroof
28. driver door actuator for full integration of key-less entry with alpine alarm.
29. new from dealer SE leather shifter knob (very rare)
30. Egay SS headers / kinda crappy design going with pacesetter instead
Going to do:
1. D2's coilover set
2. Wilwood 11" brake kit with 4 piston calipers front and rear
3. Chrome plate Mellenia IM
4. JDM sides (if i can find a set)
5. JDM Eunos Presso front bumper & chin spoiler Lip with fogs
6. German Hazard switch
7. Euro fog switch
8. Euro glass headlamps with auto leveling with switch
9. mazdaspeed leather steering wheel
10. M45 supercharger for my ZE
11. Boomerang
12. 2 more alpine window modules 8341 (contact me if you have any to sell please)
13. Lamborghini doors with remote activated automatic doors
14. mazdaspeed strut brace front & rear
15. traction bars
16. Custom chassis braces
17. custom sub boxes / to house 4 XS 10s
18. oil catch can
19. fuel pressure regulator
20. white indigo gauges with carbon surround
21. 3M clear tape to protect against stone chips
22. 30% smoked window tint
23. MS-01 rims (if i can find a clean set)
24. OBX underdrive pulley (58-9999-17X)
25. adjustable cam gears
26. belt tensioner pulleys (need top notch bearings)
27. powder coated oil pan
28. All aluminum 4 core radiator to help with engine heat
29. power steering cooler
30. oil cooler
31. Megasquirt PLP
32. pacesetter headers
