QUESTION
boneshaker27
QUESTION
Post by boneshaker27 »
is there any way to clean a fuel pump ?
just asking
or replacing it is the only way :crying:
KL01 FrEaK
Re: QUESTION
Post by KL01 FrEaK »
just replace it, if the pump is failing due to mechanical/electrical resistance(too high of an amperage or voltage draw) then its dead, new pump, meet gas tank
>> 93' GS -/- DE swap(boosted ZE comin soon)
boneshaker27
Re: QUESTION
so the fuel pump would be a cause of the car turnin over but not starting at all right
Evo_Spec
Re: QUESTION
Post by Evo_Spec »
could be, amongst many other things that could cause a car not to start, most people suggest to check your intake/vacuum hoses first, if your having a problem starting
boneshaker27
Re: QUESTION
well they are all good and no leaks
Evo_Spec
Re: QUESTION
Post by Evo_Spec »
well then the next step would be to check spark, if you get that, then yeah, it may be your fuel pump, but there are ways to check if your getting fuel or not either, trying searching on these forums about starting issues, you can use search terms like "car won't start" "troubles starting" "help with starting" or random stuff like that, there's lots of threads about it
boneshaker27
Re: QUESTION
thanks i will keep you all posted on the results
boneshaker27
Re: QUESTION
well the fuel pump is a new one so i just want to know if the fuel filter would stop it as well from starting ?
:crying:
Re: QUESTION
Absolutely.
Ryan
Re: QUESTION
Post by Ryan »
We should make it a forum habit to just answer "yes" and "no" for questions that have been explained TO DEATH.
boneshaker27
Re: QUESTION
ok thanks a million
Re: QUESTION
"yes" and "no"
