Klde swap
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
Berbz
Klde swap
Post by Berbz »
Ive been told a few different things by this question and i dont know what the best answer is.
Now for the klde mx6 v6 swap into the gs mx3, do you keep the original tranny from the gs when you swap in the KLDE motor or do i use the KLDE tranny in it? Ive heard of people saying both. I am curious to what you guys have to say about it. Thanks!
Supppp
Re: Klde swap
Post by wytbishop »
The Probe tranny is identical to the MX-3 tranny. IF you get your DE from an MX-6 or 626 it is still exactly the same size and shape but has different gear ratios and a different final drive ratio.
Any transmission from any K series engine can be interchanged. IF the question is SHOULD you..that's a different question. Opinions vary.
Berbz
Re: Klde swap
Post by Berbz »
mainly i was just wondering if you even could keep the originally tranny from the gs and if it would even work with the KLDE engine and if so, what is usually recommended to use for a tranny if you do the KLDE swap.
Thank you for the quick response too btw.
Supppp
Ryan
Re: Klde swap
Post by Ryan »
Man, there's a stickied thread in the "Transmissions" forum labeled "Official Transmission Swap Info"
It says for sure in there that you can.
Because of this, I question the integrity of your 'search'.
and its a little annoying.
Re: Klde swap
Large majority keep the stock trans, only a few swap to the Mx-6/626 trans.
Berbz
Re: Klde swap
Post by Berbz »
Alright thanks alot guys, i appreciate the responses :D
Supppp
Return to “Transmissions”
