im pretty sure this has been posted before but i swear i looked everywhere this morning and cant find it so screw it im posting again.
basically, the synchros in my tranny are going and the engine is still good so i dont really want to spend a ton of money at once. i'll eventually get a klze put in but i was thinking of putting in a klze tranny (from tiger jap.) in and using it with the stock k8 engine. also thinking of putting in a fidanza flywheel and exedy clutch with it.
are there any problems with doing this?
2.5l tranny on k8?
CrimsonReign1
2.5l tranny on k8?
93 SE, black
- solo_ryder
Re: 2.5l tranny on k8?
The klze tranny (if non lsd, which it most likely is) is the same as the tranny you have now. So is the probe, mx6, 626 trannies. They are all the same g25m tranny. The only difference is the mx6 and 626 have longer gears, so on the highway the revs are abit lower. I wouldn't recommend getting a tranny from tiger as you will pay to much. Get a k8 or klde tranny locally to save cash.
Lsd is gonna cost u a lot of money and time to source the right axles to make it work. Don't bother unless you have the time/money/knowledge to do it. 99 percent of people are running ze swaps with no lsd.
As for the fidanza. Sure, also check out aasco flywheels. Go on ebay and get a oem exedy ford probe 2.5L clutch kit. Its cheap, complete and works well for a ze with the correct break in.
CrimsonReign1
ok, ill find a 2.5 mx6 or a probe tranny and rebuild it/get it rebuilt lol
i cant seem to find a aasco flywheel, but i did find a exedy clutch kit with a f1 aluminum flywheel, are these flywheels any good? i've never heard of them.
93 SE, black
Where are you located. A few of us have spare trannies.
- solo_ryder
I wouldnt trust those F1 flywheels.
http://www.aascomotorsports.com/
Why do you need to rebuild the tranny when you get it?
i live in Aruba, could you send me one of those trannies?
CrimsonReign1
i live in bc, kelowna
i wont be doing the swap untill spring as im going to england for a few months soon
thanks for the info
thanks for the info
93 SE, black
