klze conversion
LayZieBoNeLBurNa
klze conversion
hi just got a klze conversion but still in the shop its still laggy but they telling me that my car used to be automatic converted to manual.... will this effect the response of my car
- JWMX3
Re: klze conversion
LayZieBoNeLBurNa wrote:hi just got a klze conversion but still in the shop its still laggy but they telling me that my car used to be automatic converted to manual.... will this effect the response of my car
what year is your car ? I have a 94 which i converted to manual. It had a seperate ECU for the automatic tranny. make sure to remove or at least unplug it. its underneith the center console below the radio (on 94+ models at least) near the main ecu.
The conversion should not affect the response of your ze. something like an incorrect ecu/vaf combination might.
Re: klze conversion
Lots of questions,,,,laggy. Are the fuel lines reversed? Did they neglect to connect one of the fuel rail plugs? Is the idle screw turned out too far?
LayZieBoNeLBurNa
Re: klze conversion
my car is 1994 i just got it back with the klze it seems that its lacking high end power .. it feels like it has more potential to itt ?
it is idling finee.. but wen i first turn the car somtimes the revs jst drop n raise asiff its gonna diee?
