If I had a M62 with me, i wouldnt be asking this question
In 2 years I plan to install a S/C system
I was just wondering.
If I wanted to make my own custom bracket/adapter and put it where the A/C or power steering is at, would there be enough room?
Would I have to cut into the frame or anything like that?
I'd most likely want to put a M62 where the power steering pump was at.
Fitment issues with a M62 S/C on a MX3?
Juans_93_MX3
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Re: Fitment issues with a M62 S/C on a MX3?
I cannot see how that could possibly fit there. With a header on I could barely get my engine in past the steering rack and subframe. My official prediction is no way Jose.
- hppwdn
M62 should fit in the front if you relocate the oil cooler. Dansac is putting one on his 323.
http://forums.probetalk.com/showthread.php?t=1701276273" onclick="window.open(this.href);return false;
I've toyed with the idea of twincharging the mx3 just for sport if I could ever come across a deal on an M62.
hgallegos915
It gets done in probes all the time, where the ac goes, however they have a bit more room than we do.
-hec
