Mi|<e - 94 GS BPT dyno tuned
Re: Mi|<e - 94 RS BPT
No internal damage at all, everything looks as good as the day I
put it together. Im not sure at this point what the hell caused
the pressure failure but I haven't taken the pump off completely
yet.
Toga said in an email that they would replace the pump if it is
deemed faulty... do I get another toga?
I don't want to be replacing the pump again.. they should last
the life of the vehicle and then some.
yet.
1994 MX-3 RS
B6 goodies for sale:
viewtopic.php?f=2&t=66333
What a relief! Glad to hear it, id say, remove the pump and test it. I wouldn't get why u couldn't re-use it if it's alright.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
The pump is a remanufactured unit, not new like advertised and sold as. The
pump I took off the original engine looked 10x better than this one and it saw
some abuse from the original owner. There were no pitts or score marks on the
pump from the 200k + EGT this engine came from.
This is after 10k kilometers keep in mind using Mobil 1 oil -
Im really not surprised they do not want people opening these up...
Getting a new unit from somewhere else and shimming it this time.
1994 MX-3 RS
The pressure relief valve was stuck open is why no pressure:
I cant beleive how bad it was
Cheap packing lube from toga I think is what caused this, theres no damage
upstream or downstream of the pump.
1994 MX-3 RS
mx3optidrive
Sorry for your bad luck.
Quick wiring question for you about wiring,
So is this diagram right? All you have to do is take the main relay wire from the black switch and make it go to the heated o2 on the dash harness and make the rear defrost wire from the black plug and connect it to the small white plug instead of them going to the yellow ECU plugs? No wires had to be changed in the other white plug at the bottom of the page?
I am doing this today and any info would really help out alot.
You dont have to change any of the ECU pins. The top in the above diagram is
the black connectorif I remember correctly and your just moving one wire over
one spot. And then your moving one wire from the same connector to the small
white 4 slotter for the rear defrost.
This is for a 94 RS only keep in mind. A 93 or 95 is completely different.
1994 MX-3 RS
- onlytrueromeo
I think some of the 95's are the same. I know my 95RS was still OBD1 as it was an early model year actually produced in 94.
Congrats on the car being ok!
mx3optidrive
Ya, mine is OBDI also, and my plugs are the same, including wire colors, as yours.Mi|<E wrote:You dont have to change any of the ECU pins. The top in the above diagram is
So you didn't have to change any wires around in the other White plug at all?
Thanks,
Jeff
Engine is reassembled!
new camshaft seals while im at it:
1994 MX-3 RS
More turbo goodies:
Missing:
BOV (SSQ?)
Boost controller (thinking HKS EVC)
Halfshaft - have someone on this I hope
Injectors
Pipes
Missing:
BOV (SSQ?)
Injectors
Pipes
1994 MX-3 RS
This is how a rear spring should look:
This is how the other side looks:
Cant drive the car with a borked spring but its an excuse to upgrade the entire
suspension. Parts have been ordered.
1994 MX-3 RS
Old and busted:
New hotness:
New hotness:
1994 MX-3 RS
- solo_ryder
NICE, what springs? Susp. techs?
My suspension techniques springs are green. Are those more progressive?
- solo_ryder
Yea. I had a set on my 92 and they were graphite color. I also had a set on my 94 when I bought em and they were green. So I guess they either changed colors not to long ago or they sell two colors93vtecklr wrote:My suspension techniques springs are green. Are those more progressive?
