It seems that one of the hood pins was not secured correctly, and the other one's retaining ring bent out of shape. The damage is: the CF has crack at the leading edge corners; the CF is mangled at the hinges; paint has been crushed at the fenders nead the hinges; the windshield is cracked; the roof is dented, scraped and warped.
I am so sad about this.
To prevent future mishaps, I'm going to install a small chain and clip that will connect the hood to the radiator supports. Man! I WISH I HAD THAT ON EARLIER!!!
