I couldn't believe just how substantial they were when I picked them up. In fact all that extra weight is not good. I'll have to order some two-piece rotors in the future.
Can't wait to install them.
Ah the rotors are crap. They were practically freebies thrown in so you could install the kit; they're heavy, not plated/anodized/painted, 1-piece. I bet they cost $50 each at most.Mooneggs wrote:I don't like the fact they drilled the holes over the 5 hole pattern... won't that affect the integrity of that 4th hole? especially with them being that much heavier...
I knew wytbishop would be back in short order.wytbishop wrote:The bolts are in direct shear all the time. That shear force is reduced by the friction between the wheel and the face of the rotor. If the wheel studs are not properly torqued, there is less friction between those surfaces and wheel studs can be sheared. It happens often on big rigs because of their huge loaded weights. But for a car, the problem is loose or missing wheel nuts. If the wheel can move on the stud it creates bending in the stud...snap!
The shear strength of a 5/8" grade 8 stud is ~27,000lbs min. That means your cars weight is supported in shear by 16x27,000lbs shear capacity.
For perspective...If you bolted 2 steel plates together with 16, 5/8" grade 8 bolts, you could hang 432,000lbs from it.
So if your car achieves 180 G's during either acceleration or deceleration you're in big trouble.
