IS IT WORTH BUYING THE 93 MX3
im lookn at a 93 mx3 precidia and im wondering is it reliable and does it break down easily???
projectzemx3
- fowljesse
Re: IS IT WORTH BUYING THE 93 MX3
It greatly depends on a thousand variables, however, my MX-3 is one of the top 3 most reliable cars I've owned out of about 30, including 2 Mercedes in great shape. Get the car looked at by a mechanic, and see what he says. If it was treated right, it can easily go 300,000 miles with regular maintenance.
- Ryan
and it can go forever if you can do rebuilds, bodywork, and weld heavy steels.
projectzemx3
yeah if you are mechanically inclined and plan on never taking it to a mechanic then a v6 mx3 is what you want.
NEED PARTS INSTALLED? PM ME!
Mazda's crap buy a Honda.
- Daveb
They are very reliable if not worn out. There are still many nice mx-3 with 300 k km+ . You should almost expect to spend a little to put any used car in top shape.
Get a good inspection before you lay your cash down. MX-3 are amazingly good car.
1994 GS 5 speed 1.8, fresh black paint, flowmaster muffler & Little smelly pine tree
1993 RS 5 speed SOHC with 89,000 original KMs! (rising fast though).
1994 RS 4 cyl auto- running parts car with 104,000 KMs
- fowljesse
Daninski wrote:Mazda's crap buy a Honda.
I drove a 626 across the desert many times from Phoenix, Az to Vegas, and California with the cruise control set between 100 and 110MPH for hours at a time with no problems, and have had a 323 with 200,000 miles that took alot of abuse, an RX-7 that I wasn't nice to (blew a radiator hose, and it recovered fine), and my stock GS had 120,000 miles on it when I bought it, and I drove it across Texas many times in 100+ degrees for hours at a time, and loaded it up with my worldly posessions, and drove it to Portland, Oregon. The only trouble it ever had was the distributor made by Mitsubishi.
I drive hard, and my Mazdas have held up better than any other brand I've owned.
