Marco's '95GS - Budget restoration, then LPG conversion?
projectzemx3
Re: Marco's '95 GS KLZE - Black Beast
ohhh the right hand drive is so good this picture is sick.
NEED PARTS INSTALLED? PM ME!
- mx3autozam
where did you get that strut bar..I want one of those
93 Mazda MX3 KLZE Turbo
projectzemx3
ya that strut bar looks sick but the bolts holding it on only seem to be using half of the threads. do you think that will be good enough to hold??? it wouldnt be that hard to get longer studs for the strut mounting plate.
- Ryan
There are more bolts beneath the bar, so definately yes they will hold.
- marcdh
Got it on ebay, from a uk-mx3 member that was selling his car, had to have it!mx3autozam wrote:where did you get that strut bar..I want one of those
That was a preliminary fittingprojectzemx3 wrote:ya that strut bar looks sick but the bolts holding it on only seem to be using half of the threads. do you think that will be good enough to hold??? it wouldnt be that hard to get longer studs for the strut mounting plate.
My brakes failed on Thursday on my way to work
View Worklog
View Worklog
projectzemx3
i have heard of those steal braided brake lines bursting.
it is said that the oem rubber ones allow a little bit of flex and with the ss ones too much pressure can make them burst.
i have a ss clutch line but ill stick with the rubber oem brake lines.
your lucky, brakes failing could be tragic.
- Evo_Spec
i head ss brake lines burst easily in winter too, is this true?
all I have to say is WOW... I have only see 2 of those strut bars now... nice find sir
I'm guessing you will get purple for your adjustable cam gears? maybe cut some of the plastic covers to show them off??
as always you could have lunch in your engine bay - so clean and fresh!!
yesterday i saw one of these on Ebay ... it was the real thing ...Mooneggs wrote:all I have to say is WOW... I have only see 2 of those strut bars now... nice find sir![]()
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
projectzemx3
it doesnt really appeal to me
great car mate, really nice work.
quick question, where did u get that bonnet from?
- marcdh
I chopped up this:Nd4SpdSe wrote:AHey, where did you get that guage pod from?
Then cut slots in the stock pillar, fiberglassed them in, then used filler to smooth them in. Took a LONG time to do! But I'm pretty new to all that kind of stuff! I have pics of the various stages I think, I'll add them sometime
Ebay of courseJET30X wrote:great car mate, really nice work.
View Worklog
View Worklog
so the bar does fit though including the IM having thermospacers? I want to find a bar that will work with the millenia IM and thermospacers...marcdh wrote:That was a preliminary fittingI actually had too many washers spacing it up. So it's all good now
I just shaved a little off the VRIS mounting bracket and so far have zero rubbing with the impossible millenia IM!
