Mi|<e - 94 GS BPT dyno tuned
10secSim
Re: Mi|<e - 94 RS BPT
Post by 10secSim »
THe bigger you go the more heat you'll get rid of. But from what i researched I would go 3".
I have a 2 1/2" on right now N/A...some ppl said it would slow me down n/a but i've actually got bether times at the track because it gave me more on the top end and lost some on the bottom end but with a turbo i think when ever i'll get there i'll want to up grade to 3" to be able to keep things cooler and spool up the turbo a nit faster too.
B6 1.6L DOHC, CAI, custom intake mani. with internal velocity stacks, 65mm thottle body, probe 4-2-1 header, custom 2.5" high flow exhaust, Centerforce dual friction, MS2, MSD 6A, Tokico struts, EIBACH springs.
http://www.cardomain.com/ride/2443642" onclick="window.open(this.href);return false;
Mi|<E
Post by Mi|<E »
Oil leakies :(
Also had to buy a new radiator because my stocker 15 year old one was making
pretty steam shows and horrid smells.
mx-3_4evr
Post by mx-3_4evr »
^ that looks like coolant from the oil cooler. Check everything back there again :D
Mi|<E
Post by Mi|<E »
Yep, its all apart and im putting a new radiator in while I am at it.
In addition, one of the front frostplugs weeps so its getting replaced.
While the oil is out, im putting an electric oil pressure gauge in there
that I will include wiring for and fixing the dayum leakies.
Heard autometer is a good brand, hence I shall buy one.
Mi|<E
Post by Mi|<E »
Thou shall not tick.
Mi|<E
Post by Mi|<E »
Wow been awhile since an update. Thw new HLA's eliminated the ticking but I had to
re time the belt. Dont try to keep the cam gears in time while swapping these out, just
take them off and re time the car.
Turbo and manifold have arrived, ETD BP manifold and a Garrett T3 Super 60:
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
DAMN! You lucky bastard. Can't wait to see it on the road.
Mi|<E
Post by Mi|<E »
Time to put on the rear tie bar.
Difficulty - 2/10. Pain in the a-- 9/10.
17mm nut and 21mm bolt
Theres the bolt:
The things you find when your doing repairs/mods:
Some JB Weld fixed up that hole in a mess of a hurry.
And the finished result:
Mi|<E
Post by Mi|<E »
Bearing kit for the tranny arrived. I was surprised they all all japanese bearings.
Just need the LSD now to rebuild the transmission.
colinf004
Post by colinf004 »
Amazing worklog you have going on here... some really goood info to read up on.. it would be nice to see someone do this kind of hard work (work log) in a V6 build....
Mi|<E
Post by Mi|<E »
Organized the haltech harness and labelled all the wires so installation *should*
be fairly painless.
Should go in before the end of the month.
Made a new injector harness too:
WhiteFinish
Post by WhiteFinish »
Sweet !!
That Haltech system must be asskicking :driver:
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Mi|<E
Post by Mi|<E »
Fuel rail arrived 3 days after ordering.
Mi|<E
Post by Mi|<E »
Minor update. Installing the Haltech and fuel rail with rx-7 460cc injectors to start.
And this cause it looks badass:
94drumx3
Post by 94drumx3 »
wicked! love that turbo...how much longer til she's up n runnin?
Never be afraid to try...amateurs built the ark, professionals built the titanic.
