I am thinking of Nitrous.
I have a k8 with custom cold air intake custom exhaust lowered all the way round. and i am currently thinking of running a 30hp shot of nitrouse on stock internals. what do yuo guys think? good idea bad idea? engine has been well seviced every 3000 miles or so preasure tested to make sure no leaks or bearing problems with big end. cambelt and tensioner all recently changed? any feed back would be greatly apreciated.
MX3 1.8 eunos 1996
- onlytrueromeo
Re: I am thinking of Nitrous.
Should be able to handle up to 75 shot on stock internals. Tuning, tuning, tuning. Get the computer working first!
can u remap the standard ecu with a piggy back chip? mine is the later model mx3 which as i understand is harder to remap?
MX3 1.8 eunos 1996
- solo_ryder
You can/cannot really do that, for a 50-75 shot of nitrous all you would really need is a better fuel pump and a fuel pressure regulator.. ECU tunning isnt really needed that badly for that much nitrous. You could get away with it with the above setup
i am a aware of that what i was going to do is wet shot so patch into the preasurized fuel line and attatch that to the fuel solonoid? rather than do dry shot?
MX3 1.8 eunos 1996
- solo_ryder
Thats a good idea, a wet shot into the fuel is gonna be alot safer and more efficient as you will get a equal shot into the cylinders. If you are going wet you proly only need a 60 shot to suffice as it is more efficient.
I am proly gonna run a 75 wet shot on my ZE this year.
well im going to build my own N2O kit i think i have enough general knowledge of it to give it ago and if i do make the k8 go pop then i have an excuse for a klze
MX3 1.8 eunos 1996
- cjthor
50 wet shot will be fine. Drop your plugs down one step colder. Make sure to replace your fuel filter when splicing in the fuel soleniod just to be on the safe side.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
A wet 75 shot will be fine on a K8, you could run a two stage system to have a total off a 100 shot
fit a wideband and start out on a 35 shot and then start upping the shot size but still try not to lean
the motor out.
One safely feature is fitment of a throttlebody switch so it can only be activated at full throttle
other wise you can use MSD window switches to stage the RPM of the shot.
the motor out.
yea thats what i was going to do a micro switch that only alloud the Nitrous to be release at WOT (wide open throttle) im going to build it my self with different bits and pieces. im also going to build my own pulsoid which will allow me to graduate the injection of fuel and nitrous. im hoping to hit close to the 200 wbhp as possible. but i will keep you guys updated. im just waiting for a CAM tensioner to arrive once it has got here and fitted i will start on the nitrous system
MX3 1.8 eunos 1996
MX3 1.8 eunos 1996
Building a nitrous kit should be no problem. I ran a 100-shot WET on my KLZE MX-3 for some time. The motors can handle it fine.
All you will need is a fuel pump on anything over a 50-shot. No FPR is needed, and just run the stock Ford Probe GT spark plugs those are good for over a 100-shot of nitrous and still give you a good peppy feelin all-motor.
thats awsome i cant wait to get it started. what sought of difference did u find it made between running with and wothout nitrous?
MX3 1.8 eunos 1996
please keep updating... looking to go nitrous route... debating between wet and dry right now ..
all this talk about bottles makes me want one for the KF, if i ever get it running
