You can see the GI thread, it's here:
http://www.mx-3.com/phpBB3/viewtopic.php?f=39&t=65849" onclick="window.open(this.href);return false;
The Parts
SRD Reproduction Crossmember - V6 Mx-3 Only
SRD Front Crossmember:
-"V6 owners: upgrade your 4.5lbs OEM Stamped steel Crossmember with a stronger, stiffer and 1.5lbs lighter Aluminium billet unit. This crossmember installs in minutes with basic tools. Helps to maintain the front suspension's geometry under hard cornering, provides faster steering response and significatly stiffens the chassis. CNC-machined from 6061T6 Aluminium, comes unpolished
Function: the crossmember (sometimes called transverse member) joins the two chassis pickup points of the front suspension's control arms. Under heavy cornering, tremendous forces are applied to the chassis and without proper bracing will flex and generate poor steering response. V6 MX-3s are fitted with a "C" shaped stamped steel crossmember economical to mass produce. OEM brace provides a relatively high degree of bracing but because of the "C" shape some deformation is allowed. Furthermore, torsional resistance is quite poor: you can actually twist the part with your hands. Here comes the SRD crossmember: 150% stronger longitudinally and 275% stiffer torsionnally. As a bonus part is 1.5lbs lighter. Don't let your car twist in the twisties!"
SRD Reproduction Rear Tie Bar - 4Cyl and V6 (Mx-3/323/Protege)
SRD Rear Tie Bar:
"V6 owners: upgrade your OEM rear lower tiebar with this work of art!
4 cylinder owners: your car is missing an important part especially if you have aftermarket wheels and/or lowered suspension! This tie bar installs in minute with basic tools and helps to maintain the rear suspension's geometry under hard cornering.
CNC-machined from 6061T6 Aluminium with adjustable rod-ends for easy fitment."
Hardware
Each part comes by itself. Installation is simple and uses the stock hardware.
For the crossmember, it should be noted that an impact gun really should be used. It's not necessary, but because there are literally nuts welded inside the frame, the welds can get weak from time and exposure to the elements and winter sand/salt, or the bolt is just seize from time. Regardless, the nut may come lose, which would make taking the bolt out pretty much impossible, and fixing the issue requires cutting a hole and rewelding the nut. This could be the case with even the hardware on the rear tie bar. It would be good practice to even spray those points with PB Blaster, Liquid Wrench or similar.
Price
Pricing is as follows:
Crossmember : $200 Canadian + Shipping + 5% Mx-3.com Donation
Tie Bar : $100 Canadian + Shipping + 5% Mx-3.com Donation
Shipping
- Eastern USA : $26, UPS 3-7 Days
Payments
Payment methods accepted are Paypal (+3.5%), Money Orders and Cash.
Cash and Money Orders will be send to me. For Paypal, so simplify things on the Paypal end so the donations don't get double charged either, the Mx-3.com Donation and shipping cost will be sent to my account, the payment for the parts will be sent directly to Jimmie's account.
Mine: mfortin2@cogeco.ca" onclick="window.open(this.href);return false;
Jimmie: goleafsgo57@hotmail.com" onclick="window.open(this.href);return false;
I require this information in PM (Money Order) and in the subject of the Paypal transation:
- Username
- Name
- Full Address incl. Zip/Postal Code
- 1 Personal Contact Phone Number (used on the shipping form)
- Parts requested
International shipping available, and items will be insured for each their value, in case of loss or damage during shipping and tracking numbers will be used regardless. Duties may apply. The cheapest shipping method will be used, unless a company or a more speedy delivery is requested. To mention, the cheapest shipping of the prototypes was through Canada Post/USPS, and was advertised as 7-11 business days, but expect longer in case of delays at the border.
As a note, I make no profit from them, nor do I recuperate the cost of not only paying 2x their worth to get the last set we've pretty much seen for sale in the last 2 years, as well as making a significant detour to New Jersey to pick them up. Making these parts available is my personal contribution to Mx-3'ers and Mx-3.com
Turn Around
Parts from start to finish typically takes between 1-2 weeks, being fabricated in between other jobs. They could possibly take longer, but there is also some that can and have been made as stock. PM me if you want to see if there are any available before purchasing.
More Details
The guy making the parts, Jimmie, also known as BlaznLow, is a friend of mine for the last few years. We're both part of the Explicit Contentz car club, as well as the former Team SlipStream. Colin is also friends with Jimmie, as well as part of the same club. If anyone has any doubts or any problems, I know where he lives
Although these parts are made to order, and can technically be made at anytime in the future, there is no guarantee on how long they can be produced for, pending the availability to the equipment and even the permission by the shop's owner. If that's does become the case, I would honestly look elsewhere to keep having them manufacturered, if posssible, but this is just being mentioned in case of a worse case scenario. Complete refunds will be given to those who have paid for parts that can't be manufactured.
Just a final disclaimer, that these parts are manufactured as-is and are for off-road use only. Because of the nature of the parts, there are no guarentees. Crossmember may create clearance issues and bottom out.
