Mx3 Bored V6 Throttle Body Question?
I wanted to were I could buy the new plate so I can do the job my self and not have to $200 buck for a whole new because that is a $35 machine shop job.
Re: Mx3 Bored V6 Throttle Body Question?
have the machine shop do it for you... they can cut the plate for you as well.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
with the kf tb u have to use a millenia tb gasket. And I still have not recieved my payment for it
And you may have issues with your idle..
-hec
- hppwdn
Why bored out a K8 TB(55mm) when you can pick up a Millenia TB (60mm) at the junkyard for a few bucks? Then in the future you can bore out the Millenia TB even farther if needed.
You can bolt on the Millenia TB just like that? or anything you have to change?? And is it the Millenia S one or what?? Gimmie details!
- hppwdn
Yes, it bolts right up. Only the throttle body from the regular 2.5L KL Millenia will work. I've never tried the MilleniaS one, but I would assume it's different and will not fit.
You cannot use the probe/mx6 ones because of how the IAC is placed.
Awsome! To bad I was at the junkers yesterday... Ahh well I will pick one up next time! The plugs just plug right in??
- marcdh
It's like doing a ZE swap, except just the TB so it's plug and play!
View Worklog
View Worklog
I am using the cold kit from outlaw to replace the TB Gasket. I would like to take the whole TB a apart any tips outthere the one I brought is very dirty. Yes the TB I am boring out is the Milinia one. So I need the replacement TB flap or plate.
- hppwdn
Greg 94 PGT on Probetalk has been boring out KL TBs for years. You could get the whole thing done thru him or he might just get you a plate, you'd have to PM him over there to find out.
I'm having idle problems with my ze bored out TB without IAC... I've been running a k8 bored out TB with IAC for years and it's been fine...
the main difference between the 2 TB's is the throttle cable holder (2 step vs. 1 step)
Mooneggs wrote:I'm having idle problems with my ze bored out TB without IAC... I've been running a k8 bored out TB with IAC for years and it's been fine...
Your problems consist of them doing it WRONG... lol
