KL home made block stiffner
914klze
Post by 914klze »
In case anyone was interested I've atached some pics of the block stiffner I've made. Let me know what you think good or bad.
Hmmm...?
I can't figure out how to attach pics.
Flyer
Re: KL home made block stiffner
Post by Flyer »
You need to upload them somewhere...
Robx1r
Post by Robx1r »
try photobucket its quick and very easy, i'm really interested in this
Ryan
Post by Ryan »
fowljesse
Post by fowljesse »
I'm interested, and hope you put up pics soon, with an explanation.
914klze
Post by 914klze »
Thanks for the info. I'll put them up tonight when I get home.
914klze
Post by 914klze »
onlytrueromeo
Post by onlytrueromeo »
Cool! Never seen one of these before! What does it do? It looks like it doesn't quite fit - do you need to modify the heads to use this? Please explain how it works for those of us who've never seen one!
fowljesse
Post by fowljesse »
That IS interesting. It seems like it would block cooling, and transfer heat, but if your engine was modified enough (for high revs, I assume) to need something like this, you're probably already considering an electric water pump, or other measure. Maybe Phenolic plastic would be better :shrug:
I haven't heard of a KL block flexing enough to need something like this, but I'm no KL expert!
I'm intersted in your other ideas, too!
SmoothMX3
Post by SmoothMX3 »
It's called a "Block Guard".
For people that don't know what it is... Google "Block Guard".
All the turbo guys use these when they are actually pushing decent numbers.
93 MX-3 2.5 KLZE - KL101 \\ H&R Springs \\ Short Shifter \\ 17" ADR Rims \\ 205/40/R17 Namkang Tires \\ Millenia Manifold \\ Rockford Amp \\ Rockford 12" Sub \\
--- K8 was my gateway drug.
914klze
Post by 914klze »
I chose the KL engine because of the split block style bottom end, much stronger and stiffer than traditional caps or girdles like the VG30 (Nissan 300Z). This bottom end should be able to handle 8000rpms and an easy 15lbs of boost. The top of the block on the other hand is open, as you know, which is good for cooling but allows the cylinders to vibrate at a higher frequency than the main block. during normal operation this is not a problem but under higher pressure the head gasket can get eaten by the cylinders and the block moving independently. The 300Z use a partially closed block, which good but it's cast iron = boat anchor.
The purpose of my Stiffener:
Prevent independent movement of cylinders
Minimize coolant restrictions - coolant passages matched to head gasket
Prevent cylinder from going out of round during deflagration
Next - I've some fun ideas for the turbo plumbing.
onlytrueromeo
How much did that cost to make? So it doesn't interfere w/ the heads? Would you be able to make more of those?
fowljesse
Post by fowljesse »
Nice machine work!
I'm assuming you're planning to put it in a Porsche 914. That would be awesome.. Mid engine turbo KL!
914klze
Post by 914klze »
Ya, I plan on putting the KL with the Mazda Transaxle in a 914. I was planning on 400hp.
I used aluminum 6082 and had them cut with a water jet. I think I should test them thoroughly before I consider making more of them.
onlytrueromeo
You should check this out too:
http://forums.probetalk.com/showthread. ... lock+guard" onclick="window.open(this.href);return false;
The block posting thing looks cool!
