Rear wheel bearings w/abs gear cheap in Canada?
Other - General Mazda Discussions
nightfire
Post by nightfire »
Does anyone know a place shipping rear wheel bearings (disc brakes w/abs) to Canada for a reasonable price? Napa wants almost $200 each. Can't find any on ebay.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
Ryan
Re: Rear wheel bearings w/abs gear cheap in Canada?
Post by Ryan »
Wild guesses
Rockauto.com
carpart.com
Holy crap my front ones were only $62ea. from the Dealership. I'll call my parts girl fer ya and check.
EDIT Sorry man $180 hub a--. ASB that's the best price I got. But ya Rockauto is good only problem is 96 will only be listed as a 4cly on almost every site in the States so see if the 4 is the same as the 6cly first. Cheers
Edit Edit. I think the medication kicked in last edit, sorry.
Post by wytbishop »
I went through this recently. All the hubs are the same. All years, all models. The ABS ring just presses on.
They also interchange with Protege, 323 and Escort. You may be able to find a better deal on one of these cars. I got a very lightly used set myself from another guy's part out. My dealer was asking $130ish each w/o ABS. The tone rings are $70 each though so if you're going to try to salvage your old ones, don't break em.
nightfire
Post by nightfire »
Daninski wrote:Holy crap my front ones were only $62ea. from the Dealership. I'll call my parts girl fer ya and check.
lol :p
Yea, the rear bearings come with a hub whereas the front bearings have to be pressed in. That's why they're cheaper. :/
wytbishop wrote:I went through this recently. All the hubs are the same. All years, all models. The ABS ring just presses on.
Hero tag for you sir. :) I'll order some cheapies off ebay.
- Gord
Return to “General Mazda”
