BTW may the miata intake be a better option than the mx3 intake because of the lenth of the runner? thnx to all
Is the solid lifter ever beeing done by someone here?
Cars runned 148whp at 7 psi last summer
civic_kicker wrote:Your setup is just like mine right? b6t bottom and b6de head right?
What type of cam are you using? Now im running the stock b6de cams put i have found a b6t cam to fit on the intake side and use the stock b6de cams on the exhaust side what do you thinbk of that?
I have read on turbomiata forum an how to perform the solid lifter mods bt using focus zetec lifter might be a funny thing to do i will see since the top end of my b6t is 6500 rpm do i really need ti rev past that?.... if so i will need to upgrade the entire valve train valve,valve spring retainer and all the kit wich mean a lot of cash and what about the b6t bottom my base have just being rebuilted last year to oem specs is that base and stock b6t pistons will like the feeling of 7000,8000 rpm.... not to sure im planning to run on the safe side around 200-220 whp might be right for me i also have a GT2854R BB Turbo wich might be the tool for that.
How much power at the weel's you have?
Any sugestion or idea that might help me
BTW Im about to install my Megasquirt II with the lauch controll and fuel and spark will be running Coil On Plugs.
Comments and idea are welcome.
